Hi, my dryer don't do anything when press star button, the control lights work, timer and different programs do. but do not turn or move at all, also smell burn, do you think is possible the motor is broken? thanks. Paco
Originally Posted by: ChadSimpson That could be a stripped primary shaft. Have you been putting loads in there that exceed specified maximum weight capacity? When a got home open dryer and found clip motor loose. put back together is working, Thanks for yor help.
