bafunk2
#1 Posted : Friday, August 7, 2009 3:48:51 PM(UTC)
bafunk2
I have a Maytag Dryer Model # MED5820TWO that is only 2 years old and when I set it on the sensor side to dry clothes it dries them but doesn't power down to shut off. I am wondering if it is the sensor or the timer? My husband took the back off and we blew any lint and dirt out that we could see. We want to do the repairs ourself but don't want to order parts we don't need.
Thank you
sidfink43
#2 Posted : Monday, August 10, 2009 5:22:22 AM(UTC)
sidfink43
If the timer advances in the timed cycle but not in the auto cycle, the problem is most likely in the sensor.
I cannot guarantee you that replacing the sensor will fix it (that is the problem with on-line Forums, we are just not present at the machine) but it is highly likely that it will.
Good luck.
magician59
#3 Posted : Monday, August 10, 2009 7:41:33 AM(UTC)
magician59
Find the wires that go from the sensor to the control board. Disconnect the wiring harness connector from the board and put a continuity tester on the corresponding connector contacts. Place a damp cloth on the sensor. You should get continuity. If so, replace the board. Part number: AP3713177
bafunk2
#4 Posted : Wednesday, August 12, 2009 1:51:15 PM(UTC)
bafunk2
Good luck.
:D Thank you, you were right and the Maytag Tech and I ordered the part..
bafunk2
#5 Posted : Wednesday, August 12, 2009 1:53:45 PM(UTC)
bafunk2
:D You were right it was the circuit board and it has been ordered. Thank you very much.
Amana electric dryer not working (Dryer Repair)
by Guest Yesterday at 10:43:01 AM(UTC)
Kenmore Electric Dryer 110.65132411 (Dryer Repair)
by Guest 5/1/2024 5:58:30 AM(UTC)
WGD8410SW0 Dryer l (Dryer Repair)
by Hkfmike 4/27/2024 6:00:13 PM(UTC)
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
WED4815EW1 Dryer overheating? (Dryer Repair)
by Guest 4/16/2024 12:21:03 PM(UTC)
DLEX5780WE lg dryer shutting off before the clothes are dry. (Dryer Repair)
by LMA 4/13/2024 11:00:21 AM(UTC)
help maytag comercial dryer (Dryer Repair)
by blackwell316 4/4/2024 5:05:48 PM(UTC)
grease for rear dryer bearing (Dryer Repair)
by bronn033 3/30/2024 12:57:30 PM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 3/27/2024 6:43:17 AM(UTC)
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Samsung dryer motor (Dryer Repair)
by Guest 3/24/2024 11:17:52 AM(UTC)
Replacement dryer motor W11364931 (Dryer Repair)
by Guest 3/23/2024 8:47:41 AM(UTC)
