Dryer was not getting hot enough. While troubleshooting, popped the thermal fuse on burner tube. Jumped it & seems to run ok. Replaced fuse with a new one & it ran for a few minutes, then blew. I have cleaned the exhaust ductwork & blower wheel and when it blew, was running it with the vent line off. I changed the 2 solenoids also and temperature seem fine. Any ideas
