I have a Whirlpool Gas Dryer Model # LHI5921W0 that does not maintain temperature when running through a cycle. It get some heat, sometimes, o either the Knits Gentle Low setting, or the Permanent Press Heavy High setting. What is the fix for this problem? And what are the associated Part Numbers to effect the fix.
