I bought a soap dispenser assembly from you for my dishwasher and found the part #WPL 8193920 looks the same on the outside but has a extra wire for a rinse aid sensor on the inside. (from what I see online the part is called out as a rinse aid sensor) Do you have the correct part for this dishwasher?
Note: I do not work for AppliancePartsPros.
I searched both the model number and the manufacturer's part number and both came up with the same part. So I would say that you have the correct item.
It is probably a universal dispenser and will run on units with and without the rinse aid sensing. Fact is even if your unit had rinse aid sensing I would not hook up the sensor as they are more trouble than they are worth. |
THIS FORUM IS DEAD!!!!!!! |
It is probably a universal dispenser and will run on units with and without the rinse aid sensing. Fact is even if your unit had rinse aid sensing I would not hook up the sensor as they are more trouble than they are worth. Dear Sir, thanks for your help. I hoped this was the case, I was looking for somebody to confirm this. Thanks again
