gracepet
#1 Posted : Monday, May 5, 2008 8:39:17 AM(UTC)
gracepet
How much vinegar do I add to the second rinse cycle? My repairman said that would help get dishes clean.:mad:
#2 Posted : Monday, May 5, 2008 4:37:23 PM(UTC)
If you have a white film on your glasses I would recommend to use a white vinegar too, but in a different way.
Start the normal cycle without dishes and soap and wait for about 3-5 minutes to let the dishwasher to fill up. Open the door and pour a gallon of a white vinegar in water on the bottom. Do not restart the dishwasher for about 12 hours to let vinegar to dissolve all built ups and then finish the cycle. Repeat this procedure a few more times if needed.
Do the same thing once in a quarter to prevent such problems.
Whirlpool cabrio washer codes (Washer Repair)
by Guest 4/20/2024 11:59:12 AM(UTC)
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
door open code Whirlpool WRX986SIHZ00 (Refrigerator & Freezer Repair)
by Guest 4/20/2024 5:54:26 AM(UTC)
Whirlpool Side by Side with icemaker Model WRS588FI (Refrigerator & Freezer Repair)
by Guest 4/19/2024 4:08:15 PM(UTC)
How does Whirlpool agitate? (Washer Repair)
by Alex Pabloroux 4/12/2024 1:40:40 PM(UTC)
Whirlpool WRS325FDAM04 (Refrigerator & Freezer Repair)
by nhred71 4/11/2024 10:32:03 AM(UTC)
Whirlpool Ice Dispenser Auger will not run (Refrigerator & Freezer Repair)
by WhirlpoolDave 4/1/2024 12:44:26 PM(UTC)
Whirlpool Duet MDL# WWF8400TW02 New Drain Pump (Washer Repair)
by 1Oskydoodle! 3/30/2024 10:30:29 AM(UTC)
Whirlpool ler5635lq0 timer issue (Dryer Repair)
by Rolandtd 3/26/2024 6:15:44 AM(UTC)
Whirlpool WFW5620HW3 F6E3 Error (Washer Repair)
by hunt_ak 3/25/2024 12:55:01 PM(UTC)
Whirlpool Oven - Controls Don't Work (Oven Repair (including Ranges and Cooktops))
by Guest 3/25/2024 10:18:22 AM(UTC)
Kenmore/Whirlpool GB22DKXJW00 - evap fan replacement no ground (Refrigerator & Freezer Repair)
by DIY2024 3/24/2024 1:07:07 AM(UTC)
Multiple failures in Whirlpool oven? (Oven Repair (including Ranges and Cooktops))
by Guest 3/22/2024 6:55:50 AM(UTC)
whirlpool range GS395LEG (Oven Repair (including Ranges and Cooktops))
by Guest 3/18/2024 12:17:23 PM(UTC)
Whirlpool WRF757SDEM01 led light problem (Refrigerator & Freezer Repair)
by Guest 3/16/2024 1:02:12 PM(UTC)
