Register | FAQ's | New Posts | Today's Posts | Extras |
» Does not drain |
![]() Model Number: 58714439202 Brand: Kenmore Age: 1 - 5 years
![]() Does not drain. Hose is clear, as is path to check valve within the washer (all interior components removed/inspected). What are the functions of the relay and the switch, could they be the problem? The switch tests fine - it is activated by a float. Washing function seem to work fine, I assume the motor/pump (one unit on this model) is not getting the signal to drain the water OR that part of the motor/pump has failed. Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Quote:
No buzzing, could be a hum or silent. Ran the rinse only cycle w/ no heat dry - it make lots of noise while rising then pretty quiet after that. Any way to test the motor/pump? |
![]() Nope, 3 inches in the bottom.
Sears is out of stock on the motor but I think it is returnable if and when I were to obtain one and that is not the problem. Not sure if there is a way to test the motor. DW has been "uninstalled". |
![]() Quote:
I would set to just rinse w/ no heat with the unit out of the cabinet. Can you perhaps point me to a schematic to see what wires to the motor do what? I assume white is (+ or -)power and the others get power only during certain phases of the cycle. |
![]() Quote:
https://www.dropbox.com/s/4ifsjviaox1uwdv/kenmore.jpg I can set to rinse/hold and check all the leads (using white as common) while rinsing and when the power drops from the lead supplying power during rinse check the others. This would assume that power goes to a different lead for draining. |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Maytag D/W: - drain after wash issue but cancel/drain works fine after.... | diesan2011 | Dishwasher Repair | 1 | 07-23-2014 05:59 AM |
Dishwasher won't drain, push cancel/drain button will clicking then hum, no draining | bluelakes77 | Dishwasher Repair | 0 | 11-10-2011 09:17 PM |
My Hotpoint washer won't drain or spin, but it will if I drain the hose by gravity? | ks_becker | Washer Repair | 0 | 08-10-2010 10:25 AM |
bosch shu9925 - drain pump works, won't drain after cycle | mjbarr | Dishwasher Repair | 0 | 10-16-2009 01:11 PM |
Timer will only advance to fill and wash not drain (have to manually move to drain) | zibdi1 | Dishwasher Repair | 0 | 06-15-2009 03:47 PM |
