vsquared
#1 Posted : Saturday, June 23, 2012 7:09:22 PM(UTC)
vsquared
My LG WM2277HW will start to fill with water but the drum will not rotate, only hums, and in about 4-5 minutes the LE code comes up. The washer does not drain the water, only does the LE code. The washer is 8 years old. Replaced the Drive Motor Stator Assembly part AP4438648 and the Rotor Assembly part AP4438635. However, still have the same problem. Do I need to replace the Wiring Harness part AP4439126 or is it some other problem? I looked at the wiring harness and no outward sign of problem (no frayed wires or obvious damage).
chaleff
#2 Posted : Wednesday, July 4, 2012 9:49:40 AM(UTC)
chaleff
Does anyone know why my washer drum wont move. the light dims but it doesn't move
