reedv
#1 Posted : Sunday, May 22, 2011 10:40:07 AM(UTC)
reedv
i just changed out my inlet valve and standpipe on my dishwasher and now there's no water coming into the dishwasher, where as before it was overfilling. Any ideas???
#2 Posted : Tuesday, May 24, 2011 2:02:54 PM(UTC)
Check that you did not accidentally hit the overfill/float mechanism.
The overfill switch should be activated.
Check that the valve is getting water.
Check that there is 120 volts across the fill valve when it should be filling.
If the voltage is there and you do not get water, I would say you received a defective valve.
Whirlpool cabrio washer codes (Washer Repair)
by Guest 4/20/2024 11:59:12 AM(UTC)
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
door open code Whirlpool WRX986SIHZ00 (Refrigerator & Freezer Repair)
by Guest 4/20/2024 5:54:26 AM(UTC)
Whirlpool Side by Side with icemaker Model WRS588FI (Refrigerator & Freezer Repair)
by Guest 4/19/2024 4:08:15 PM(UTC)
How does Whirlpool agitate? (Washer Repair)
by Alex Pabloroux 4/12/2024 1:40:40 PM(UTC)
Whirlpool WRS325FDAM04 (Refrigerator & Freezer Repair)
by nhred71 4/11/2024 10:32:03 AM(UTC)
Whirlpool Ice Dispenser Auger will not run (Refrigerator & Freezer Repair)
by WhirlpoolDave 4/1/2024 12:44:26 PM(UTC)
Whirlpool Duet MDL# WWF8400TW02 New Drain Pump (Washer Repair)
by 1Oskydoodle! 3/30/2024 10:30:29 AM(UTC)
Whirlpool ler5635lq0 timer issue (Dryer Repair)
by Rolandtd 3/26/2024 6:15:44 AM(UTC)
Whirlpool WFW5620HW3 F6E3 Error (Washer Repair)
by hunt_ak 3/25/2024 12:55:01 PM(UTC)
Whirlpool Oven - Controls Don't Work (Oven Repair (including Ranges and Cooktops))
by Guest 3/25/2024 10:18:22 AM(UTC)
Kenmore/Whirlpool GB22DKXJW00 - evap fan replacement no ground (Refrigerator & Freezer Repair)
by DIY2024 3/24/2024 1:07:07 AM(UTC)
Multiple failures in Whirlpool oven? (Oven Repair (including Ranges and Cooktops))
by Guest 3/22/2024 6:55:50 AM(UTC)
whirlpool range GS395LEG (Oven Repair (including Ranges and Cooktops))
by Guest 3/18/2024 12:17:23 PM(UTC)
Whirlpool WRF757SDEM01 led light problem (Refrigerator & Freezer Repair)
by Guest 3/16/2024 1:02:12 PM(UTC)
