Brand: Whirlpool double oven Model Number: wod51ec0hs20 Main Symptom:Time, Power, Temp, Clock etc What happens & when: 4 years old. Has never maintained accurate time. Will not connect to wifi. Displays power failure at random times…after hours, a few days. Last couple of months temp drops when baking and last week would literally turn off while baking. I am a master electrician and degree in electronics so, the electrical aspect is all ok..breakers, wiring, conncetions. No spikes in power or other devices would have problems too..computers etc.
Error Code (if any): No Error Codes displayed
Parts or tests already tried: Replaced CB W1125-3187
Given that symptom set—and assuming you’ve already verified the 240 V supply, neutral/ground, connections, and breaker—I’d focus on the oven’s control electronics rather than incoming power.
For the WOD51EC0HS20, the clues line up unusually well:
Clock has never kept accurate time → control/processor or timing circuitry issue.
Random “Power Failure” indications without an actual supply interruption → control is resetting/rebooting.
Temperature dropping during bake → control may be intermittently dropping the heating-element commands.
Now shutting completely off during baking → likely progression of the same reset/power-supply problem.
The most useful test would be to meter L1-L2 at the oven itself while it is operating and leave the meter connected until the failure occurs. If you maintain ~240 VAC through the instant the display/control shuts down, you’ve essentially separated the house supply from the appliance electronics.
I’d then check the control’s low-voltage power supply and connectors for heat damage, cracked solder joints, or an intermittent connection. If line voltage remains solid but the control actually reboots—as opposed to simply stopping heat—I’d put the main appliance control/control-board assembly high on the suspect list. A bad temperature sensor by itself wouldn’t explain the clock errors, Wi-Fi problem, false PF indications, and whole-unit shutdowns.
One distinction would narrow it further: when it shuts off during baking, does the display go completely black and then boot back up, or does the display stay alive while only the heating stops?
The oven was one year old when we purchased this house and the prior owner did not say anything about issues.
The clock has never kept the correct time.
Never able to set the wifi even though it displays the wifi name.
Power Failure is random, nothing consistent.
No Error Codes displayed.
Temperature drop has happened 3-4 times over the last month of so. Per what my wife says, she checks about 20 minutes after putting something in the oven and noticed, when it did happen, that Power Failure displayed. Clicks on Skip since the clock does not work correctly, checks temp and the last time it was 50 degree below the initial temp so it had been off for a bit of time. She resets it, guessing on how long to continue baking and stays close by. (So far everything turned out ok, maybe a little dry).
So, does the oven actually go off, screen go blank at anytime??? Having replaced the one CB, what is the second almost identical board next to the one replaced for? Neither does it show up on Whirlpool schematics?
Thinking, pull the power jumper to the second board and see what happens, if the control panel does not come on??? Maybe replace that board too.
I agree, everything points to the Control Board(s).
Checking L1 - L2 is not going to solve anything as if one phase failed which would make the oven Power Fail, there would be other devices having problems, turning off, primarily one of the computers, TVs etc.
As far as checking power if your house was built in the last 30 or so years the stove and dryer circuits and the hot water heater if its electric. Have to be on dedicated stand alone 240v ac circuits. nothing else will be on that circuit. Also your control board and clock run on 120v ac which is one leg of the 240v ac required to operate electric elements. So you have a L1 and an L2 just for the elements
Having been in the electrical business since 1975, a master electrician and contractor since 1980, I understand how it all works. The house is 4 years old.
Since Whirlpool’s schematics only show Part “#3” control board, what is the other almost identical control board sitting next to Part #3.
At this point without anyone knowing exactly what is wrong except the one who designed and programmed the control boards, I will pull the oven out, find the Part # on the second board, purchase and replace it.
Everything points to control board(s) failure. Obviously, it was not the main one I replaced.
Apparently the response I sent this morning did not go through or I forgot to press Reply.
Without pulling the oven back out to look at the label on the board, I do know it starts with 1126-1??? The picture I took of it is not clear enough.
From all I found online, this 1126-1169 does not show up on schematics. From the Sheet / Manual you provided, this board is for the lower oven which my wife uses maybe 3 times a year.
I think the best thing is to buy this board and see what happens as there is nothing else that can have the affect / effect of all that is going on…time off, no wifi connect, loss of temp, power failure. However, I would have thought the main board 1125-3187 would have taken care of those issues, but maybe the problem is routed through the lower oven board.
