Whirlpool oven exterior glass replacement
I have a whirlpool oven that I need to replace the exterior oven door glass. The model is sf330peww6, the part number is ap2969964, the glass is no longer available from Whirlpool. Is there a replacement/substitute part I can use? Thanks:)
Unfortunately the manufacturer has discontinued it and made no replacement. You can try the advise posted earlier by [COLOR=“Red”]denman[/COLOR]: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/27549-frank.html
