| » Frank |
Model Number: Mer6771AAW Brand: Maytag Age: 5 - 10 years
I NEED A front glass for the upper door of a gemini range the model #is mer6771aaw.the part #is 13 series-74005577 and the serial#is 17542470zm. Itis a white door. Can;t find anywhere.Isthere something that I can interchange with another brand. thanks
bigbluetrk17,
Unfortunatly the manufacturer has discontinued it and made no replacement. Since everything is researched by model numbers and not by size all you can do is keep checking around to see if anyone would have one left in stock or see if you can find a glass company that can make it to the size needed.
__________________
Need a part? Buy appliance parts from us. Fast delivery and great prices. Thank you for supporting our free repair help forum. |
Measure the size of glass required and the window size/location. A diagram may help. Also the thickness.
Then make the rounds to appliance stores, if you cannot obtain a glass, you may be doing this anyway. Perhaps you will get lucky and find a unit with the same size glass and a window which is close to yours. The glass is tempered so getting one made will be difficult and you cannot use standard glass. Did notice that the window has a foil heat shield, you could use the metal tape that is used for sealing heating ducts for this.
__________________
| Display Modes | |
| Frank | FBRTKO | Oven Repair (including Ranges and Cooktops) | 2 | 11-11-2009 06:02 PM |
| frank | frose | Refrigerator & Freezer Repair | 1 | 02-25-2008 02:36 PM |
| Frank | fvas | Washer Repair | 1 | 08-29-2007 08:59 PM |
