Whirlpool Modular Icemaker installed in Kenmore 106.955953
Won’t make ice. Icemaker does not fill with water. Water OK to door water dispenser. Have used hair dryer to make sure supply tube is not frozen.
Icebmaker cycles when jumpered on TH and regularly
Resistance on LH is 72 Ohms to 72 Ohm specified. OK
Resistance on LM low at 72 OHm to 4400 OHM specified. ???
Resistance check on VN is 250 Ohm, low to 300 spec.
On TH jumper cycle, water valve get 108 volts at proper time
On changing leads to water and icemaker valves the following:
7a. ice maker lead to water valve, then TH jumper, valve cycles at proper time dispensing water to door.
7b. water lead to icemaker valve, press water, no water to icemaker
Ergo - ice maker is OK even though motor resistance does not match spec, and ice maker valve is bad even though resistance is close to spec.
[QUOTE=v2k04;47819]it has a dual valve one for the water disp and one for the icemaker both coils should ohm the same[/QUOTE]
The resistance measured at the electrical leads at the water valves is as follows:
for the water dispenser to door valve is 285 ohm and
for the water dispenser to the ice maker valve is 247 ohms
don’t quite match, and neither is close to the 300 ohm specified in the manual
I’m thinking I just need to try to replace the valve since the unit makes ice if manually filled, cycles normally, dispense water is the electrical leads to the valves are swapped, and the ice maker thermostat is jumpered.
[QUOTE=v2k04;47968]force cycle it and have your meter leads ready on the VAC scale and see if the valve gets voltage on the icemaker valve when its calling for water[/QUOTE]
I already know the answer to this question. Yes there is voltage, because when I switch the electrical leads I get water from the water dispenser. However, just to make sure I checked it. 108 volts.
Guys - I have a Whirlpool side by side w/ an icemaker that quit supplying water. Followed your t/s’ing - made perfect sense, I have the same issue - bad solenoid on the IM side. Swapped the 2 control leads around got the same result - water did work to the door dispenser.
Thanks a bunch - you probably saved me a hundred bucks on a service call - which I’d only do a last resort anyways.
