I don’t know why only the dishes on lower rack cleaned but not the upper rack. I already checked all the spray arms, they are not clogged.
Any idea?![]()
Most likely the problem is a foreign objects inside the pump chopper and the pump inlet protector, causing not enough pressure in the wash system.
Remove the top cover and the inlet protector cover and clean everything.
There are 3 screws at the bottom I already unscrewed. I have no clue how to take them apart.:mad:
You can go to applianceaid.com to get info. Look for a half round pump housing cover, remove screw and pry off, you will find the screen in there.
Remove the upper dish rack.
Remove the water feeding tube for the upper spray arm.
Remove 4 screws (#3 on the break down diagram) holding the top cover (#1 on the break down diagram).
Remove the inlet protector (#8) holding by the tab on the right side.
Check the chopper (#6) for any clog.
Clean all debris and assemble in the reverse order.
Just looked at one of these today, when you put the chopper back in, make sure it engages the motor impeller, if not, it is worn out and you will have to get a new one.Also, the drain pump and main pump alternate on and off to back flush the screen: a check valve allows this.
The check valve is on the right side of the chopper, a black thing stuck in the housing.
Check valve P# 8268375; chopper assy. P# 8268383
After I cleaned and reasembled everything, the clean light is flashing.
Please help.:mad:
Reset the control as described in the technical sheets.
You guys are AWESOME !!!
I give you guys grade : A++++++++++++++++
My dishwasher working perfect.
Thanks.
Don’t count your blessings yet: If your chopper fails in the future, you will need to pull the dishwasher and replace the pump impeller.
[quote=Gene;8058]Remove the upper dish rack.
Remove the inlet protector (#8 on the break down diagram) holding by the tab on the right side.
the screws for the cover on my Whirlpool GU2500 sre not the slotted type shown in the diagram but some sort of hex type. I couldn’t find an allen wrench to fit. Any idea what type of tool is needed?
You will need to buy a set of torx bits for these.
Thanks for the suggestion about torx bits!
I have a Kenmore model 66517514200 and I think the Chopper is the problem. However, I can’t get the inlet protector off to get to the chopper. I removed 2 screws and can’t see any others. It will not budge and I don’t want to damage the part trying.
Can someone help with this? Thanks.
Rotate the screw-end of the protector upward to remove the part and expose the chopper assembly.
I use a flat bladed screw driver to pry on the right side of the half round chopper housing, eventually it will work loose. Usually a build up of soap residue makes it stick. If the chopper screen is clogged, you will need a new chopper and check valve in the bottom of the housing.
[quote=richappy;8410]Just looked at one of these today, when you put the chopper back in, make sure it engages the motor impeller, if not, it is worn out and you will have to get a new one.Also, the drain pump and main pump alternate on and off to back flush the screen: a check valve allows this.
Check valve P# 8268375; chopper assy. P# 8268383[/quote]
Hello all I was following this procedure and found a part 8268297 it is a small white plastic coneshapped item. I’m not sure where it came from I was wiping out the bottom and found it. I think it may have fell from the top where the upper water feed is. Help! I don’t want to put back together with extra parts.
thanks:eek:
[quote=BrianT267;78446]Hello all I was following this procedure and found a part 8268297 it is a small white plastic coneshapped item. I’m not sure where it came from I was wiping out the bottom and found it. I think it may have fell from the top where the upper water feed is. Help! I don’t want to put back together with extra parts.
thanks:eek:[/quote]
Never mind i found it it does go in the upper water feed i think it is a nozzle. Putting the chopper back in and getting it to engage the impeller is a bear.
I put it back together and it still does not work. What is the next step? the chopper had scum on it but turned as did the impeller. The check valve looked ok it was intact I don’t know if the rubber gets stretched out over time. Should those to things be replaced or is there something else to look at?
What was the original problem, no water pressure? If so, you might have a pump motor running backwards!
