Water coming out of door
`Came home to water on floor, took off front lower panel looking for leak, water dripped on my head from door, thinking the gasket must have failed, how the heck do you get this thing off if that is the problem, thanks Randy.
Hi.
  • Remove the 3 screws at the rear of the top.
  • Slide back and lift off the top.
  • Pull out the dispenser and take the 2 screws out.
  • Work out the clips on the top of the control panel and remove it.
  • Remove the screws on the top of the front panel.
  • Release the door latch (3 screws).
  • Take off the spring holding the bellows to the front panel.
  • Remove the bellow from the panel.
Follow the attached instructions.
The bellow AP6011758
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136839
Simon.
Duet sport - The door switch and the bellows removal - 1.pdf (558.9 KB)
Duet sport - The door switch and the bellows removal - 2.pdf (167.4 KB)
