Washer won't spin
I have a Whirlpool Quiet Wash 1 washing machine that won’t spin during the spin cycle. It will drain the water just fine, but won’t spin unless i manually help it along, and then won’t spin very fast. I’ve already replaced the motor coupling. Any other ideas?
Mike,
In order to provide most accurate advice we need the complete model number of the washer.
The model number is LSB6200KQ0
Mike,
The first thing I would do is check the drive block (#17 on the diagram).
Remove the washer cabinet (instructions attached) and then follow the instructions from one of our previous posts: http://forum.appliancepartspros.com/washer-repair/373-not-spinning.html
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LSB6200KQ0 | AppliancePartsPros.com
How to remove the washer cabinet.pdf (43.5 KB)
