Washer does not appear to be spinning
When cycle is finished clothes are still dripping wet. Water is draining from washer. Sometimes I can put a light load in and it will spin just fine but it must be a very light load. What is the problem?
The problem can be a bad drive block (#17 on the diagram), a bad basket drive (#1 on the diagram) or a bad clutch.
You have to remove the washer cabinet
[youtube]OlAFQnkapLM&rel=1[/youtube]
to access these parts. The instructions are attached.
You can find more useful information in one of our previous threads: http://forum.appliancepartspros.com/washer-repair/373-not-spinning.html
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LSB6300LW0 WASHER - DIRECT DRIVE | AppliancePartsPros.com
How to remove the washer cabinet.pdf (43.7 KB)
