Wall oven
Service person just left house.
Display panel went put on Whirlpool oven.
Used oven last night
Set temp for 380, checked back 20 minutes later, temp was only 225.
Display panel blank.
Shut oven off, display panel still blank.
About 10 minutes later display panel came back on.
He stated display pane(board)l no longer available, was made in Japan.
Factory was next door to nuclear plant that blew up.
Fact or fiction???
After reading how bad whirlpools are I might just buy a new wall oven, but I need to find out it story I was told is TRUE.
Your model number is incomplete, please check it.
Whirlpool RBD305 Built-in Electric Oven
Sorry but I still cannot find any info on just RBD305.
Find your model number - AppliancePartsPros.com
Below is what comes up at AppliancePartsPros.
There is a list of this series of units in the Matching Model Numbers section.
Parts for RBD305 - AppliancePartsPros.com
Am on the phone with
whirlpool now. With the correct model #RBD305PRS00.
The part is available.
Thanks for your time
Don
Parts for Whirlpool RBD305PRS00 Wall Oven - AppliancePartsPros.com
Could be that the control thermal fuse is blown.
This is usually up close the the control board and looks like a little torpedo in the wire.beklow is an example.
It does not show up in the parts but that is not unusual.
If it is blown you will need to call for the correct part number.
Note that there will not be a visual indication that it has blown.
AP6009502
RBD305.pdf (504.1 KB)
