My Husband unscrewed the front pannel to tighten the handle which was falling off. When he did 2 white plastic pieces came out. I think they are called door guards. Does anyone know how to put them back in or know where they go? I can’t seem to find a diagram anywhere. Also, is it normal for the white insulation on the inside to be a bit moldy? Yuk!! Thanks for any help…
Hi Tracy,
Slide them back in over the hinge, lining up the door guard square tab with the hinge lever square notch.
Hello
I have a loose handle on my Bosch DW - only about 3 yrs old.
Is it necessary to remove the whole inside panel to tighten it?
What pitfalls are there - like springs or other things that will fall out? Is there a seal than will be difficult to reset?
Thanks,
TED GROAT
Hi Ted,
What is the complete model number of the dishwasher?
I can’t tell the model without pulling it out, but the manual is for models
SHE66C, SHX56C, SHV56C, SHX57C, SHV57C and SHY56A
TED
You can find the model number on the right side of the door or behind the bottom panel.
Ok - found it - SHX56C05UC / 23.
I am also curious about one other thing. Dishes and glasses dry properly, but plastic containers like Tupperware remain wet. Any suggestions.
Thanks,
TED
[FONT=Verdana][COLOR=#000000]To remove the outer door, open the door and remove the T-20 Torx screws located on each side of the inner stainless door. [/COLOR][/FONT]
[FONT=Verdana][COLOR=#000000]Return the door back to its upright position, and bring the bottom of the door panel out toward you, then slide the top of the panel down and out from under the fascia panel. [/COLOR][/FONT]
[FONT=Verdana][COLOR=#000000]As the outer door is being removed, the left or right door guards may shift or fall out of place. To reposition them, slide them back in over the hinge, lining up the door guard square tab with the hinge lever square notch. Please note: door guards must be in place before reinstalling the door panel. [/COLOR][/FONT]
[COLOR=#000000][/COLOR]
[COLOR=#000000]Tighten the screws holding the door handle.[/COLOR]
[COLOR=#000000]Assemble in the reverse order.[/COLOR]
[COLOR=#000000]Longer drying time for a plastic dishes is normal due to their porous surface.[/COLOR]
[COLOR=#000000]Gene.[/COLOR]
Thanks very much for your assistance.
TED ![]()
I am also having a problem with a loose door handle, on my Bosch dishwasher, and just wanted to check and see if the procedure for getting to the door handle screws was the same for model: SHX46A05UC / 14
Thanks,
Mark
Hi Mark,
You can use the same technique but should be very careful because the outer door on your dishwasher is much heavier. Hopefully the following door break down diagram will help you better understand the door design.
Here are the break down diagrams for the Bosch dishwasher Model SHX46A05 UC/14 (FD 8211-)
Gene,
Thanks for the info, fixed it without any problems. I was able to take off the screws from the right side (side where the handle was loose) and the top and then get to the screw which holds the handle on without having to take the entire door off which really helped.
Thanks again.
Mark
Is the control module behind the door cover?
[QUOTE=Gene;25552][FONT=Verdana][COLOR=#000000]To remove the outer door, open the door and remove the T-20 Torx screws located on each side of the inner stainless door. [/COLOR][/FONT]
[COLOR=#000000]Gene.[/COLOR][/QUOTE]
Hi Gene,
It is a SHE44C05UC/40
It seems like a control module will cost $105 plus $10 to ship. Bosch said the module is covered in their 5 year warranty but my Appliance repairman charges $200 minimum for a home visit. So I can pay $200 for him to do it or buy it for $115 and do it myself. I’m an engineer and I’m pretty good with electronics but I’m a dishwasher virgin… Advice?
John
[QUOTE=Gene;115867]What is the complete model number of the dishwasher?
Gene.[/QUOTE]
Hi John,
You can by this part for less than a $100 and this part is not too difficult to replace yourself. The file with instructions is attached to the reply.
- The control module AP4434739
Call the Appliance Parts Pros customer service or use the live chat to find out the ETA on the part.
How to replace control module.pdf (23.2 KB)
Gene, you’ve been a “God-send”. I took the door off and sure enough the control module has the “burnt-out” soldier joint. I re-soldiered the connection and just ran through a cycle and it works great! THanks a ton for the disassembly instructions.
John
You are welcome John. I’m glad you were able to fix it with no cost to you.
[quote=Gene;15937]Hi Tracy,
Gene.[/quote]
I have a Bosch SHU4302UC dishwasher and I took off both the door panel and the top panel to resolder the circuit that was causing my unit to run 3 - 4 hours per full wash cycle (didn’t realize I only had to take off the top panel). I think I got everything right except for these two darn black plastic door guards. It’s driving me nuts, they seem to be like square pegs in a round hole. Please help - any diagrams?
