Range Oven Cooktop Repair – Temp, Ignition, Burner Tips
Oven temp off, burner will not ignite, or display dead? Get cooking appliance help.
Post title must be: brand + full model number + gas or electric + main symptom
Example: “GE JGB735SPSS gas oven will not heat past 250”
Body checklist:
• Temp swings, flame color, element glow
• Recent part changes
• Photos of igniter, sensor, or control board
Before posting, run a quick search in this forum to see if your issue is already solved. If you suspect a bad part, paste the exact AppliancePartsPros.com product URL so others can confirm it fits your model.
