I have an LG front load washer. The hose leading from the drain pump has a split in it and needs to be replaced. Can this hose be replaced without having to order and replace the entire pump casing or will part number AP5078561 work?
Well, working from memory and without one of these things in front of me I think you will be fine with just that part, assuming there is no other damage of course.
Just make sure you have the right part - LG seems to have multiple parts that look similar but are subtly different. There are several sites online that can cross reference the parts for you with your model and serial #. They were great.
If it’s the black bellows hose I just posted how to do this here : http://forum.appliancepartspros.com/washer-repair/276931-replace-lg-bellows-drain-hose.html
Good luck
