Discuss
Replace the LG Bellows Drain hose
 in
Washer Repair
Taking some tips from this post : http://forum.appliancepartspros.com/...procedure.html Symptom : water on the floor during wash cycle - progressively getting
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Replace the LG Bellows Drain hose
  #1 (permalink)
Old 08-03-2011, 06:30 PM
Junior Member
phantomvirus is on a distinguished road
Thumbs up Replace the LG Bellows Drain hose
Model Number: LG Front Loader   Brand: -other-   Age: 5 - 10 years
LG Washer Pump Replacement Procedure
Symptom : water on the floor during wash cycle - progressively getting worse.
Solution : replace the bellows drain hose from the bottom of the tub due to a leak in the 6 year old hose. Attack the problem from the rear of the machine so as not to have to disassemble the drum, electronics, etc.
Tools needed :
You also need a good flashlight - it's DARK under there.
Step 1:Unplug the washer, turn off the water and pull it away from the wall.
Step 2: STOP - Did you unplug the washer and shut off the water supply lines. Remove the drain access cover, pull the drain hose out, pull the plug out of the end of the hose and drain the tub into a towel or a dish. There will still be a lot of water in the system but draining it helps
Step 3: Remove the four screws holding the rear plate of the washer to reveal the back of the drum. THIS is what we are going to replace - it is under the drum and connects the lower drain to the drain pump in the fron of the washer.
Step 4: Remove the small diameter black hose from the white drain connector. It simply pulls out as it is not under pressure – no clamps or clips needed.
Step 5: Unscrew thePhillips head screw holding the top of the drain hose – this makes things easier – and the second Phillips screw you can just back out (no need to remove it) and slide the top of the drain hose off. Remove the spring clamp using a pair of channel locks and slide the hose off the drain connector. Place the connector to the side.
Step 6: loosen the retaining ring surrounding the outlet at the bottom of the drum using a Phillipshead screwdriver. You need to loosen it enough to slide if off the mount.
Step 7: Remove the spring clamp in the front of the machine (that connects to the pump) using your channellocks again. And then remove the old bellows hose assembly.
Step7a: I wanted to see what my issue was so I took the time to inspect the hose and I found the hole that was the culprit. 6 years and hundreds of washes and the hose split at the seam.
Step 8: Prepare the new hose by transferring all the clamps from the original hose. Take care in sliding the hose into the front spring clamp – BTW - reattaching this is a nightmare.
Note: if I were to do it again I would have used a screw/band hose clamp and ditched the spring clamp completely. I wasted over 30 minutes fighting to get the hose and clamp onto the pump inlet port. 20/20 hindsight would have saved me a ton of aggravation. I ended up using the needle nose locking pliers to keep the clamp open while I slid the hose onto the pump inlet port and then released the clamp when done – major league PITA – but I did not want to deal with removing the entire front of the washer since I did not have the spring pliers to put the rubber drum gasket back on.
Step 9: Working in reverse put the hoses back – starting with the pump in the front of the machine –attach and tighten the clamp, then the main drain mount and finally the white drain connector – HINT – wet the inside of the hose and the white plastic piece and they will slide together much easier. Rotate the drain connector to be sure that you can align the screw holes in the back of the drum. Attach the springclamp.
Step 10: Run a full empty cycle through the washer to be sure that the hoses are tight and properlyconnected. Assuming no leaks - put the back plate back on using the 4 screws you removed in step 3.
Parts : $10
Time : 1 hour (should have been 1/2 that due to front spring clamp challanges)
Related Models
Amana LG1009W DRYER- GAS
Amana LG1101 DRYER- GAS
Amana LG1112 WASHER-TOP LOADING
Amana LG1112 DRYER- GAS
Whirlpool LG2001XSW0 Residential Dryer
Amana LG2112L DRYER- GAS
Amana LG2112W DRYER- GAS
Amana LG2401 DRYER- GAS
Amana LG2412 WASHER-TOP LOADING
Amana LG2412 DRYER- GAS
Amana LG2501 DRYER- GAS
Amana LG2512 WASHER-TOP LOADING
Amana LG2512 DRYER- GAS
Amana LG2811 DRYER- GAS
Amana LG2812 WASHER-TOP LOADING
Amana LG2812 DRYER- GAS
Amana LG2902 WASHER-TOP LOADING
Amana LG2911 DRYER- GAS
Amana LG2912 WASHER-TOP LOADING
Amana LG2912 DRYER- GAS
Whirlpool LG3001XMW0 Residential Dryer
Whirlpool LG3001XMW1 Residential Dryer
Whirlpool LG3001XMW2 Residential Dryer
Whirlpool LG3001XPW0 Residential Dryer
Whirlpool LG3001XSW0 Residential Dryer
Whirlpool LG3006XPW0 Residential Dryer
Amana LG3412G DRYER- GAS
Amana LG3412L DRYER- GAS
Amana LG3412W DRYER- GAS
Amana LG3512L DRYER- GAS
Amana LG3512W DRYER- GAS
Amana LG3812L DRYER- GAS
Amana LG3812W DRYER- GAS
Amana LG3912L DRYER- GAS
Amana LG3912W DRYER- GAS
Frigidaire LG400AXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400AXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400MXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LG400MXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LG400MXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LG400MXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LG400SXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400SXD2 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400SXD3 Wwh(v1) / Laundry Center
Frigidaire LG400SXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400SXW2 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400SXW3 Wwh(v2) / Laundry Center
Amana LG4209L DRYER- GAS
Amana LG4209L2 DRYER- GAS
Amana LG4209W DRYER- GAS
Amana LG4209W2 DRYER- GAS
Amana LG4219L2 DRYER- GAS
Amana LG4219W2 DRYER- GAS
Amana LG4309L DRYER- GAS
Amana LG4309W DRYER- GAS
Amana LG4319L2 DRYER- GAS
Amana LG4319W2 DRYER- GAS
Amana LG4409L DRYER- GAS
Amana LG4409W DRYER- GAS
Amana LG4429L DRYER- GAS
Amana LG4429W DRYER- GAS
Whirlpool LG4441XWW0 Residential Dryer
Whirlpool LG4441XWW1 Residential Dryer
Amana LG4509L DRYER- GAS
Amana LG4509W DRYER- GAS
Amana LG4609L DRYER- GAS
Amana LG4609W DRYER- GAS
Amana LG4809L DRYER- GAS
Amana LG4809W DRYER- GAS
Amana LG4909L DRYER- GAS
Amana LG4909W DRYER- GAS
Whirlpool LG4931XMW0 Residential Dryer
Whirlpool LG4931XSW0 Residential Dryer
Whirlpool LG4931XTW0 Residential Dryer
Whirlpool LG4931XTW1 Residential Dryer
Whirlpool LG4931XTW2 Residential Dryer
Whirlpool LG4936XMW0 Residential Dryer
Whirlpool LG4936XMW1 Residential Dryer
Whirlpool LG5201XTW0 Residential Dryer
Whirlpool LG5201XTW1 Residential Dryer
Whirlpool LG5321XTW0 Residential Dryer
Whirlpool LG5531XKW0 Residential Dryer
Whirlpool LG5531XKW1 Residential Dryer
Whirlpool LG5531XMG2 GAS DRYER
Whirlpool LG5531XMN2 GAS DRYER
Whirlpool LG5531XMW0 Residential Dryer
Whirlpool LG5531XMW1 Residential Dryer
Whirlpool LG5531XMW2 GAS DRYER
Whirlpool LG5531XPW0 Residential Dryer
Whirlpool LG5531XSW0 Residential Dryer
Whirlpool LG5531XSW1 Residential Dryer
Whirlpool LG5536XPW0 Residential Dryer
Whirlpool LG5551XTG0 GAS DRYER
Whirlpool LG5551XTN0 GAS DRYER
Whirlpool LG5551XTW0 Residential Dryer
Whirlpool LG5601XMW0 Residential Dryer
Whirlpool LG5601XPW0 Residential Dryer
Whirlpool LG5601XSW0 Residential Dryer
Whirlpool LG5601XSW1 Residential Dryer
Whirlpool LG5606XPW0 Residential Dryer
Whirlpool LG5651XKW0 Residential Dryer
Whirlpool LG5651XKW1 Residential Dryer
Whirlpool LG5651XMW0 Residential Dryer
Whirlpool LG5651XMW1 Residential Dryer
Whirlpool LG5701XKW0 Residential Dryer
Whirlpool LG5701XMW0 Residential Dryer
Whirlpool LG5701XMW1 Residential Dryer
Whirlpool LG5701XMW2 Residential Dryer
Whirlpool LG5701XPW0 Residential Dryer
Whirlpool LG5701XSN0 GAS DRYER
Whirlpool LG5701XSW0 Residential Dryer
Whirlpool LG5706XPW0 Residential Dryer
Whirlpool LG5721XPW0 Residential Dryer
Whirlpool LG5721XSW0 Residential Dryer
Whirlpool LG5721XSW1 Residential Dryer
Whirlpool LG5726XPW0 Residential Dryer
Whirlpool LG5751XFW0 Residential Dryer
Whirlpool LG5751XKW0 Residential Dryer
Whirlpool LG5751XKW1 Residential Dryer
Whirlpool LG5751XMW0 Residential Dryer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need help with LG drain hose robertn Washer Repair 2 08-04-2011 01:08 AM
My Hotpoint washer won't drain or spin, but it will if I drain the hose by gravity? ks_becker Washer Repair 0 08-10-2010 10:25 AM
Replace drain hose at dishwasher connection toyotaboy Dishwasher Repair 0 05-15-2010 01:01 PM
replace drain hose shiking Washer Repair 1 08-27-2009 01:10 PM
replace Bellows David Monholland Washer Repair 1 02-25-2009 06:05 PM
