Brand:Whirlpool Model Number: wtw8127lc1 Main Symptom: :Check the drain What happens & when: I keep getting a “Check that the Drain is clear” fail code.
Error Code (if any):F9E1
Parts or tests already tried: Clearing everything connected to drain/pump. I’ve pulled the drain pump several times and ran 15 gallons of water thru the drum/drain with the pump disconnected, Water drains unobstructed. I disassembled the drain pump and the impeller does spin in segments of a rotation. Unsure what’s next. There IS 20 Ohms resistance (not 0) across the drain pump plug with it disconnected.
Your 20 Ω reading is actually good. Whirlpool’s service information gives the drain-pump winding at roughly 17.8–21.8 Ω, so 20 Ω is right in specification.
Also, the segmented/notchy feel when turning the impeller by hand is normal for this type of magnetic pump motor. I would not replace the pump just because of those two observations.
What F9E1 actually means
F9E1 is Long Drain. Importantly, the control isn’t simply detecting whether water can physically flow out. It sets F9E1 when the water-level reading doesn’t decrease as expected while the drain pump is operating. Whirlpool specifically calls out the pressure hose/pressure sensor as another cause.
Given that you’ve already demonstrated free flow through the tub/drain path with 15 gallons of water, I’d go here next:
Check whether the pump actually runs during commanded drain. Put the washer into diagnostics/component activation and command the drain pump ON. Listen/feel underneath for the pump running. If it doesn’t run, you need to determine whether it’s losing power through the harness/control rather than condemning the pump from resistance alone.
Check the pump wiring harness. Whirlpool’s procedure specifically has you check continuity from the pump back to the main control after confirming pump resistance. A broken/intermittent wire or poor connector can give you a perfectly good 20 Ω pump that isn’t being energized reliably.
The pressure-sensing system is now high on my suspect list. Inspect the small pressure hose running from the tub/pressure dome up to the main control’s pressure transducer. Look for a kink, pinch, leak, soap residue, water or debris in that hose/dome. Whirlpool specifically instructs technicians to disconnect the hose from the control and clear the hose/dome if contaminated.
Run the Water Level Pressure Sensor diagnostic. During the test, the indicated water level should increase while filling and decrease while draining. If the tub physically empties but the diagnostic still thinks there’s water in it, you’ve essentially isolated the F9E1 to the pressure hose/dome or pressure transducer/main control, rather than the drain plumbing.
The most useful test right now
I wouldn’t buy a pump yet.
Put some water in the machine and initiate Drain/Spin. Watch what physically happens:
Pump runs + strong water flow + tub empties, but F9E1 eventually appears → pressure sensing/main control problem is very likely.
Pump doesn’t run → check for power to the pump/harness/control.
Pump runs but discharge is weak → pump can still be mechanically bad despite measuring 20 Ω.
Is there a particular resistance reading I can get across the pump. Ive only checked the wiring plug but what should the motor read across the contacts?
Both the Drain Pump and the harness (disconnected) have 19.9 Ohms of resistance.
Both wires to the drain pump measure 0.4 Ohms fro the plug to the Control board.
The pressure sensing hose is clear, no kinks, free of water/debris/residue and is otherwise in great shape. Not sure what you mean by “Dome”. I do not see any transducer on the pressure hose. It simply fits onto the outside of the tub and runs up to the Board and connects.
I commanded the drain pump on and it simply hums for 30 secs and then stops. I read 120 V AC at the board when commanded on. I added a couple cups of water to the tub and it pushed nothing out.
The transducer for the pressure sensor is built into the board, the dome is a air space that the sensing hose attaches to, yours must be internal to the washer tub.
Disconnect the pressure hose at the board and blow thru it back into the tub to make sure there are no internal obstructions. Also did you check for any damage to the hose, sometimes they will develop a leak from rubbing against the tub. Next run your washer as before and test to see if the code comes back. If it does disconnect the hose at the tub end and blow into it then pinch the hose so the pressure can’t escape and test the washer, does the code return? what I’m doing is trying to determine if there is a fault with the pressure system and where the fault may lay.
Jeff, Thank you. I did each of those steps. The problem wa the noise the pump was making want as it should not does anything purge out when I introduce water forcing me to drain the water manually. I have the back off and the machine up on 4 ammo cans so I can catch the water. I decided to remove the pump, disassemble it and command it on. Viola, the pump motor would vibrate, heat up but never rotate the impeller as if trying but frozen. I’ve ordered a pump. I appreciate all your help. Would you happen to have the Tech Sheet for a Whirlpool Dryer Model WED8127LC2?
