LG Spray arms not working
All spray arms aren’t working. I removed all three and they weren’t clogged. Machine fills, runs through cycle and then drains fine, except no water is going through the arms.
I took apart the housing and couldn’t find any clog, so I’m not sure if it’s the pump. I would think that the pump and motor work since it drains. Not sure what/how to check something else. Anyone have this problem/solution? Could it be that the water isn’t getting into the pump to go through the arms? Not sure how to check if this is clogged. Thanks.
Nick
[COLOR=#000000][LEFT][COLOR=#000000]Hi: I have 2 of the WN0532HW LG Washers. One on the first floor and one in the basement. (purchased spring 2004) There are 2 pumps, one for draining and the other for circulation. [/COLOR]
[LEFT][COLOR=#000000]The drain pumps seem to work fine but the circulation pumps make grinding noise. Could anyone tell me how this pump works. Does it pump water to the top of the drum? Is it under pressure and causes a spray? How do you tell if the water is getting thru the hose and to the sprayer, if it’s a sprayer.[/COLOR]
[COLOR=#000000]I can’t see any water coming down from the top or any spraying. Does this circulation help clean the clothes? Thank you.[/COLOR][/LEFT]
[LEFT][COLOR=#000000]Read more: http://forum.appliancepartspros.com/washer-repair/211915-lg-water-pumps.html#ixzz1KyY77xds [/COLOR]
[COLOR=#000000]http://forum.appliancepartspros.com [/COLOR][/LEFT]
[/COLOR]
[/LEFT]
