Leaking Dishwasher (diverter motor)
[QUOTE=jp_austin;876003]Yeah I got it fixed. The trick it to remove the seal, I cleaned mine with CLR to remove the gunk inside of it. I flipped it over so the sealing spring/ring is pointing down. I used silicone grease on the shaft. Slide the seal over the shaft all the way down. Then install the diverter. As I stated earlier the connecter for the small switch was essentially gone. I just soldered to the small board directly the wires. The seal goes into the housing but not as deep as if you install it first. That is the trick. The seal being lower on the shaft seals tighter and no more leaks. I have checked on it half a dozen times to make sure it’s still holding up and not a drop. The diverter motor on mine clacks a bit and I may look to see if the internals of the diverter valve are OK. I can hear the water being shuttled between the upper and middle sections now (the job of the diverter) so I think it’s working OK.
The pump on mine slightly shifted over time and it’s slightly hanging down from the housing. I tried to get it back into the original location a couple of times but the design sucks. I used a small piece of foam rubber under the pump motor to push it back up into position and that reduced a lot of the clack noise. Sad that this dishwasher is only three years old but it’s only designed to last at best about four to five years based on the crappy parts being used.[/QUOTE]
I believe jp_austin has found the key solution, i.e. it is necessary to install the seal on the diverter motor shaft first. My seal was also installed incorrectly at the factory. Since I could not find a new seal without purchasing the entire sump assembly, I cleaned and lubricated the original seal and installed per ap_austin’s procedure. It is now leak free for two cycles. Hopefully the seal will not shift over time.
It is hard to believe that Kitchenaid will not at least sell the troublesome seal separately. They have ruined their (and other Whirpool product) reputation with me. Otherwise, we have been pleased with the product (KUDE40FXBL4).
I will also note that the first time this dishwasher leaked I had called a repair shop. They replaced the damaged diverter motor but not the seal. They were also unaware of the seal being installed incorrectly and certainly were not aware of jp_austin’s procedure.
Thank You jp_austin
