Kitchenaid Icemaker not working
there is not a shut off arm? but i let it get cold again in the freezer and voltage came up to 120 the i jumped the test ports with a wire like you suggested and the arms or motor rotated1/2 turn and stopped?
Did you remove the jumper after a half of a revolution?
The temperature bellow 10°F is very important for ice maker performance.
Gene,
Same problem, moved cover, light stays of with the on-off switch set to on. Model# KSRI25FNBL00
Bradford
[QUOTE=Gene;10127]Hi Jay
Open the freezer door, press in the emitter flaper door (on the left side) to unblock the optics beam and view the diagnostics “status” LED on the right side.
Post you findings and the complete model number of the fridge.
Happy New year!
Gene.[/QUOTE]
HI. Hopefully you still check this thread :slight_smile:
I have a kitchen aid KSRP25F. When flap on left closed the LED light is solid red. When flap open the LED blinks red twice, pause, blink twice, pause etc…
Help please?
