[quote=Gene;19229]Roy,
Assuming the “on-off” switch on the right side panel is “on”, check if the plastic tube coming into the ice maker is frozen (remove the ice maker first). Replace the water inlet valve if there is frost.
Locate the water inlet valve on the back of the fridge. Switch the wires between the ice maker solenoid and the water dispenser solenoid. Depress the water release lever on the door and see if water will come to the ice maker.
If it would then the ice maker has to be replaced.
If it would not then the water inlet valve has to be replaced.
The part number for the water inlet valve is [COLOR=#800080]AP3160649[/COLOR]
The part number for the ice maker is AP4318635
Gene.[/quote]
Gene:
I am having the exact same problems as Roy. Following your advice above, water does come when the water release is pushed.
I have two questions:
1.) Where do I find the complete part number? I am not sure I have the same model as Roy…
2.) Do I really need to replace the entire ice maker? It seems only the solenoid would need replacement…
Thank you for all your input here…if you ever have a question about a STIHL power tool, please let me repay you with my expertise.
