HI
I have Kitchen Aid Dishwasher KUDL02IRBS1 the unit will not start.
On Control Panel I have the following lights light-up when I press the button and some are off
Heavy Duty (ON)
Normal Cycle (ON)
Rinse Only (OFF)
HiTemp Scrub (OFF)
Heat Dry (ON)
Cancel (OFF)
Start (OFF)
I already replace the Control Board, but it didn’t help.
Does anyone know the pin-out from the ribbon cable connector so I can test the switches.
Does anyone know what else I can do to troubleshoot?
Thank you
KUDL02.pdf (244.0 KB)
