Kitchen AId Blender
Does anyone have experience with replacement of a coupling drive on a blender? My concern is that the new one have some flexability to allow it to be slipped onto the disc on the drive shaft. Thanks
[SIZE=3][COLOR=#000000][FONT=Times New Roman]Instruction Sheet for KitchenAid Blender Coupling Drive Installation[/FONT][/COLOR][/SIZE]
[FONT=Times New Roman][SIZE=3][COLOR=#000000] [/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][COLOR=#000000][SIZE=3]1)[/SIZE] [/COLOR][SIZE=3][COLOR=#000000]Unplug Blender[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][COLOR=#000000][SIZE=3]2)[/SIZE] [/COLOR][SIZE=3][COLOR=#000000]With blender facing you, insert flat blade screwdriver (3/8 to 7/16 inch) between the black coupling drive and the blender housing.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][COLOR=#000000][SIZE=3]3)[/SIZE] [/COLOR][SIZE=3][COLOR=#000000]Raise up on the screwdriver to turn the coupling drive clockwise (it is a left hand thread so the coupler keeps tight during use). Keep making ΒΌ turns until the coupling drive comes off. Do not worry about bending the old coupling drive. You are going to throw it away.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][COLOR=#000000][SIZE=3]4)[/SIZE] [/COLOR][SIZE=3][COLOR=#000000]There is a flat spot on the blender shaft and construction of a flat tool is possible, but not necessary.[/COLOR][/SIZE][/FONT]
[FONT=Times New Roman][COLOR=#000000][SIZE=3]5)[/SIZE] [/COLOR][SIZE=3][COLOR=#000000]Check the threads on the blender shaft and clean the old metal shavings from the threads. Hand tighten the new coupling drive. It will be kept tight during normal use due to the left hand thread design and the clockwise spinning of the blades.[/COLOR][/SIZE][/FONT]
We have combined questions related to Kitchen Aid blender drive coupling in to one thread.
Kitchen Aid blender drive coupling installation instructions: http://forum.appliancepartspros.com/blender-repair/62084-how-replace-coupling-kitchenaid-blender.html
