Discuss
How to replace coupling on KitchenAid blender
 in
Blender Repair
UPDATE : We have made a step by step video on how to replace this KitchenAid blender coupling. See the
Appliance Repair Forum > Appliance Repair Help > Blender Repair » How to replace coupling on KitchenAid blender
  #1 (permalink)
Old 02-03-2008, 06:38 AM
Admin / APP Team's Avatar
Administrator
APP Team
Admin / APP Team has disabled reputation
Cool How to replace coupling on KitchenAid blender
UPDATE: We have made a step by step video on how to replace this KitchenAid blender coupling. See the clip below.
Replacing a blender coupling on a Kitchen Aid blender is easier than it seems. See complete instructions in the attached file below (4 easy steps with photos).
If you need a replacement coupling, we have it here:
Original Whirlpool / Kitchen Aid made - Part number: AP2930430
Part Details - WHIRLPOOL Coupling, drive, part number: AP2930430
Ads By Google
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #2 (permalink)
Junior Member
jbarker is on a distinguished road
Default Kitchenaid Blender coupling drive
I have the subject blender, the rubber coupling drive is breaking and needs replacing. Does anyone know if it just pops off with some lever action or there is another mechanism for removing/reinstalling it? Model is KSB5.
thanks
  #3 (permalink)
Old 02-19-2008, 09:31 PM
Junior Member
Default Thanks
Love the machine when it works, but this is the second that's gone bad. First I sent back while it was under warranty. Thanks a bunch for your help.
  #4 (permalink)
Old 03-18-2008, 08:12 AM
Junior Member
mrsanky is on a distinguished road
Post Kitchenaid Blender coupling drive answer
I have had my blender for about 7 years and it just went bad! At least it's a cheap replacement! Hope this helps ya!
  #5 (permalink)
Old 02-01-2009, 06:53 AM
Junior Member
Liguori is on a distinguished road
Default
Quote:
thanks
Instruction Sheet for KitchenAid Blender Coupling Drive Installation
1) Unplug Blender
2) With blender facing you, insert flat blade screwdriver (3/8 to 7/16 inch) between the black coupling drive and the blender housing.
3) Raise up on the screwdriver to turn the coupling drive clockwise (it is a left hand thread so the coupler keeps tight during use). Keep making ¼ turns until the coupling drive comes off. Do not worry about bending the old coupling drive. You are going to throw it away.
4) There is a flat spot on the blender shaft and construction of a flat tool is possible, but not necessary.
5) Check the threads on the blender shaft and clean the old metal shavings from the threads. Hand tighten the new coupling drive. It will be kept tight during normal use due to the left hand thread design and the clockwise spinning of the blades.
  #6 (permalink)
Old 06-11-2009, 06:14 AM
Junior Member
nillissen is on a distinguished road
Lightbulb kitchen aid ksb50b4 coupling drive replacement
Please advise on the removal and install of the coupling drive before I go at it with improper tools due to impatience.I am ordering the part now.
Thank you.
  #7 (permalink)
Old 07-31-2009, 09:46 AM
Junior Member
Rich Hughesbutton is on a distinguished road
Default
Hi, Ihave the same problem.............. I understand that the coupling has reverse threads. How the heck do you replace it?????
  #8 (permalink)
Old 08-16-2009, 03:44 AM
Junior Member
senile is on a distinguished road
Talking Kitchen Aide Blender Coupler replacement
I found this to be a quick and easy repair. Use a thin 9/32" ignition wrench that fits under the broken coupler and onto the shaft. Then place a channel lock plier on the broken coupler. While holding the wrench in place, twist the coupler CLOCKWISE (reverse threads). The coupler will quickly unscrew. Put the new one on and tighten it counter clockwise. Use of the blender will tighten it more.
The Whirlpool part is Part number: AP2930430
  #9 (permalink)
Old 09-02-2009, 07:58 PM
Junior Member
El Bee is on a distinguished road
Default break that thing off
This way really works! The metal on the coupler is super soft and weak so when you bend it off with the screw driver the threads oh the blender's housing aren't damaged at all. Super easy, and super quick, it only took me about 5 minutes. If you can save a $150 blender do it. Times are hard
  #10 (permalink)
Old 10-25-2009, 08:04 PM
Junior Member
btmathe is on a distinguished road
Smile Kitchen Aid coupler
Thanks for all the info. I just changed mine. In addition to the screwdriver to lift up on the old coupler, I used a pair of needle nose pliers to hold the shaft while turning it clockwise.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Coupling Drive for Kitchen Aid blender Mgordon Blender Repair 6 12-08-2009 11:26 AM
