Background on my problem:
- My oven started beeping for no reason.
- I was told to replace the Electronic Range Control part #WB27K5344.
- I received a GE replacement part #2084360010 (model#'s 164D5063P004, and WB27T10492).
- I received the part but it did not include a way to conect the control panel 14 point ribbon to the Electronic Range Control.
- Do I need to replace the entire control panel or can I get a connection for the ribbon?
- If I do buy a new control panel will it come with the ribbon connector?
Thank You for your help! Jim
