how do I replace water line in freezer door of whirlpool side by side
how do I replace the water line in the freezer door because it has been broken inside the door and it leaks when I use the water dispenser?
Todd,
The instructions are attached to the reply.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL ED22TEXHW00 | AppliancePartsPros.com
Removing the water dispenser fill tube.pdf (234.0 KB)
I apparently have the same or similar problem. I can get water to dispense at the union at the base of the fridge, but there must be a plug or break in the line between the union and the door dispenser.
Gene, how do you install the new fill line? How do you route it back up through the door to the dispenser?
[quote=RMC;208835]I apparently have the same or similar problem. I can get water to dispense at the union at the base of the fridge, but there must be a plug or break in the line between the union and the door dispenser.
Thanks[/quote]
What is the complete model number of the refrigerator?
It’s a ED25CQXFB02.
And I did fix my problem (left the door open ~ 1 hour; apparently the line was frozen).
But just in case (preparing for the possibility?) I would like to know how to change the line.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL ED25CQXFB02 | AppliancePartsPros.com
Thanks Gene.
Any tips on how to feed the new line back through the door?
[quote=Gene;210173]The instructions are attached to the reply.
Gene.[/quote]
Gene, I have a similar problem with my GE Profile TFXW27FLR. The water dispenser line was severed apparently right at the point that it enters the hinge on the bottom of the Freezer Door. (At least, I think it goes in/out at the hinge - there is no line there left to verify.)
The mechanism works great but when I press for water, it shoots out of the line at the bottom of the fridge!
How do I replace the line running from the water spout, through the door, out the hinge (I think) and into the union (which is clearly visible at this time?
Thanks for your prompt reply.
Cybolt
[quote=cybolt;247316]Gene, I have a similar problem with my GE Profile TFXW27FLR. The water dispenser line was severed apparently right at the point that it enters the hinge on the bottom of the Freezer Door. (At least, I think it goes in/out at the hinge - there is no line there left to verify.)
Cybolt[/quote]
Try to remove the recess panel (#22 on the diagram).
Here are the breakdown diagrams and Freezer door replacement parts for General Electric TFXW27FLR Refrigerator | AppliancePartsPros.com
[quote=Gene;247374]Try to remove the recess panel (#22 on the diagram).
Gene.[/quote]
Yes, I have removed the recess panel from the inside of the freezer door. None of the parts in the picture above are immediately visible. The only thing I notice is a silver box held by two hex screws that appears to be the backside of the dispenser mechanism.
If you can not access it this way, then the only choice is to remove the inner door panel.
[quote=Gene;247983]If you can not access it this way, then the only choice is to remove the inner door panel.
Gene.[/quote]
Is that the entire top to bottom panel with the shelves and all, held in place by all those hex screws hiding under the “gasket” or “pad” around the door?
Is that like rebuilding an engine? Do you run the risk of not getting it back together again properly if you do so?
Is there a high screw up factor involved?
Is there a way to come in from the front?
[quote=cybolt;247987]Is that the entire top to bottom panel with the shelves and all, held in place by all those hex screws hiding under the “gasket” or “pad” around the door?
Is there a way to come in from the front?[/quote]
Yes, it is the whole panel (#19 on the diagram).
It is not a simple job, but there is no any other way.
[quote=Gene;247998]Yes, it is the whole panel (#19 on the diagram).
Gene.[/quote]
So seriously… is there a high screw up factor? Does one risk not getting it back together OK or is it simply removing all the screws, replacing the tube and putting it back together?
I’m OK in these situations… not a mechanic but can figure stuff out OK.
BTW, lovely day in SoCal, isnt it? I’m out in Upland, at the foot of Mt Baldy.
[quote=cybolt;247999]So seriously… is there a high screw up factor? Does one risk not getting it back together OK or is it simply removing all the screws, replacing the tube and putting it back together?
BTW, lovely day in SoCal, isnt it? I’m out in Upland, at the foot of Mt Baldy.[/quote]
It is very nice, especially in Orange county.
You have to remove the door from the fridge and put it on a flat surface to prevent it from twisting when you’ll assemble it back. This is the most risky part of the job. Otherwise it’s not going to be very difficult.
[quote=Gene;248006]It is very nice, especially in Orange county.
Gene.[/quote]
Many thanks!
Have a great weekend!
You are welcome. Don’t work too hard!:slight_smile:
I’ve got the same problem with a Whirlpool ED25CQXHW03. How do I replace the water line inside the freezer door to the dispenser?
DID ANYBODY EVER FIGURE OUT HOW TO SNAKE THE NEW TUBE BACK THROUGH THE DOOR OF THE FRIDGE?
Erikda1
Gene.[/quote]
[QUOTE=Erikda1;383316]DID ANYBODY EVER FIGURE OUT HOW TO SNAKE THE NEW TUBE BACK THROUGH THE DOOR OF THE FRIDGE?
Erikda1[/QUOTE]
