Ok water has been leaking from underneath my washer apparently for awhile and just now noticed it :(. I am debating on what to do. If I call a repairman it will cost 125.00 to just show up and then 100 a hour labor plus parts so probably looking at a minimum of 300 to see if the machine is repairable. Does anyone know what might be causing the leak? I clean out the filter accessed from the front all the time and the water inlets and outlets are dry as a bone so what is underneath this machine leaking? Is this an easy inexpensive fix or do I throw the machine out and get a new one?
Hope someone can help soon as the laundry is stacking up. Thanks
Ps…is there an easy way to slide these big machines out other than using a 2 wheeler?
Not many people respond to queries about LG appliances and I am not familiar with them either but the following link shows, with pictures, one person’s tear down of a machine similar, but not identical, to yours. This may be of some help.
[COLOR=black][FONT=Times New Roman][COLOR=black]http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?31496[/COLOR][/FONT][/COLOR]
[quote=River525;487538]Ok water has been leaking from underneath my washer apparently for awhile and just now noticed it :(. I am debating on what to do. If I call a repairman it will cost 125.00 to just show up and then 100 a hour labor plus parts so probably looking at a minimum of 300 to see if the machine is repairable. Does anyone know what might be causing the leak? I clean out the filter accessed from the front all the time and the water inlets and outlets are dry as a bone so what is underneath this machine leaking? Is this an easy inexpensive fix or do I throw the machine out and get a new one
open the top panel and back panel–run the washer–look for water leaks. my leaked from the bellow. see part number AP4436407. good luck finding yours.
