I have gotten into test mode, display shows t01.
How do I run the test?
I pressed and held the start button and it beeped and displayed a 3
that is the correct code for this model number.
I have been unable to take the next step.
Try to turn the select knob.
Here are the breakdown diagrams and Replacement parts for General Electric WBVH6240F0WW Washer | AppliancePartsPros.com
[quote=Gene;773067]Try to turn the select knob.
Gene.[/quote]
When I turn the select knob. The display shows, t14, t13, t12, t11, t10, t9, t, t7, t6, t5, t4, t3, t2. for each turn,
I figured out how to do the diagnostic test.
When I run test 11, the spin test. The machine does not spin. Display shows a zero. The next step also does not spin and the display shows a zero.
Where do I go from here?
What did it show for t2?
What was the original problem?
Washer tumbles before filling with water. Afterwards, it doesn’t tumble or spin.
t1 returns 00
t2 returns 00
T10, drains washer but doesn’t tumble.
T11, doesn’t spin at all and returns 0 for both tests.
Each time the washer starts, a wake up routine should be initiated:
The door locks.
The wash basket briefly tumbles in both directions.
The door unlocks.
The door locks.
The fill cycle begins.
Did it do it?
If you did hear the click from the door lock, verify if the door was really locked.
[quote=Gene;773411]Each time the washer starts, a wake up routine should be initiated:
The door locks.
The door unlocks.
The door locks.
Did it do it?
Gene.[/quote]
Yes, it went through the start up sequence as you describe. I let the machine run full cycle in order to generate any applicable codes. It ran as I would have expected. It drained after the wash cycle and refilled for the rinse cycle. The only thing I can detect is that the basket doesn’t tumble and/or spin when it should.
Check the inverter and the motor as described in the attached files. Post the results.
How to test and replace the inverter.pdf (49.9 KB)
How to test and replace the motor assembly.pdf (110.6 KB)
Service panel removal.pdf (46.5 KB)
[quote=Gene;773420]Check the inverter and the motor as described in the attached files. Post the results.
Gene.[/quote]
Thanks for all your help. The plastic box only contains connectors so I am assuming that this is not the inverter. I assume the inverter is the metal box to the rear of the plastic box. It has two heat sinks on it. That box is humming when the drum should be turning.
You are on the right track. The inverter is probably the culprit.
- The inverter AP4421584
Front View.pdf (96.8 KB)
Disconnected wiring plugs, entered t10.
There is no voltage between the blue and red wires.
Mating plug has 2 wires blue and tan.
The other plug has 6 wires. It does not have red, white and blue wires.
Cannot see any plugs on the motor. Looks like wiring harness goes inside the casing.
If there is no 120 VAC presents while the washer should tumble, then very likely the problem is a bad control board.
Where are they exactly? Is the inverter damaged?
