GE PDWT480P00SS control module replaced but not functioning
Brand: GE
Model Number: PDWT480P00SS
Main Symptom: bad control module
What happens & when: Original control module shorted out, replaced with WD21X10363 but not working
Error Code (if any): none
Parts or tests already tried: Powered down, replaced module, powered up, let run through initial text/calibration, will not work
If it is powering up initially that makes me wonder if it might be the door latch assembly not reading the door as closed. Does the keypad seem responsive at all?
The door latch is fine. I get the beep when opening and closing so that is fine. The keypad was working then did not, but I snugged up the ribbon connection and it was working again. But the wash cycles are not working properly.
Is there a way to reset the module to factory settings so I can start all over again?
Note that my original board is “General Electric Model No: 165D8853G002” on the blue label and the replacement is “General Electric Model No: 165D8853G005”.
Are the boards model specific in that they are specific to the model wash cycles, etc.? I know there are other models from this product year that have different wash cycles.
You’ve replaced the control board, so that already reset everything. And those #s aren’t going to have anything to do with this.
What do you mean by the wash cycles aren’t working properly? What happens when you start a cycle?
Okay so what is our next step? What information would help resolve this?
What is meant by the wash cycles aren’t working properly? What happens when you start a cycle?
Does the water valve activate? Does it just sit there? Is it flashing anything?
Will it let you into diagnostic service mode? Here’s the tech sheet for that model.
PDWT480P00SS 31-30600-Mini-Manual-808.pdf (530.9 KB)
I cannot enter service mode by holding down arrow and heated dry together for 3 seconds. Here is a video I just took: https://youtu.be/1Z6ejBiw0vs
That’s going be an issue with the keypad WD34X11469 which has been discontinued by the manufacturer and is no longer available for purchase. The manufacturer does not list a compatible substitute or replacement part.
The control board is doing what it is supposed to with the information being given to it by the keypad and turning on components, starting the cycle, etc.
https://www.appliancepartspros.com/ge-keypad-wd34x11469-ap4368203.html
I’d disagree. I think the control module isn’t matched to the specific model and - however it does it - isn’t sending the right information to the dishwasher. I can get a new keypad. When I do an it exhibits the same behavior - then what?
The reason I’m saying this is that this is the second replacement module I’ve tried and the two replacements are exhibiting different behaviors - and have different behaviors on the keypad.
I’d like to know if there is a way to reset the control module back to the “factory” setting so it runs through the setup process again.
That is the correct control module according to the manufacturer. Our site and the manufacturer show the keypad as no longer available/discontinued. The consensus between my fellow techs and I is that this is an issue with the keypad and not the control board.
There is no reset procedure for the control board that we have been made aware of by the manufacturer.
So once the control board has gone through the initial setup/calibration it can’t do it again?
Not according to any information available to us.
