Hi – I have a GE XL44 Gas oven/range…and need to replace the oven gas igniter. I removed the oven floor and BUT cannot see how to remove the flame spreader (plate sitting under the gas tube) so I can remove old igniter (which is attached to a gas tube)… can anyone offer a suggestion? When I removed several screws around the perimeter – the spreader sank down about 1/2 inch but can’t move it after that… HELP?!
The wires hang down behind the bottom drawer – so I can get to them – but will need to cut and use wire nuts to connect new igniter since connectors are different configuration – will that be an oprational problem.
[RIGHT] [/RIGHT]
Dan BurnsView Public ProfileFind all posts by Dan BurnsAdd Dan Burns to Your Buddy List
