Discuss
Help - instructions to install oven igniter
 in
Hi -- I have a GE XL44 Gas oven/range...and need to replace the oven gas igniter. I removed the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Help - instructions to install oven igniter
  #31 (permalink)
Old 01-23-2009, 03:55 PM
Dan Burns Dan Burns is offline
Junior Member
Dan Burns is on a distinguished road
Default trouble removing the GE flame spreader to replace gas igniter
Hi -- I have a GE XL44 Gas oven/range...and need to replace the oven gas igniter. I removed the oven floor and BUT cannot see how to remove the flame spreader (plate sitting under the gas tube) so I can remove old igniter (which is attached to a gas tube)... can anyone offer a suggestion? When I removed several screws around the perimeter -- the spreader sank down about 1/2 inch but can't move it after that... HELP?!
The wires hang down behind the bottom drawer -- so I can get to them -- but will need to cut and use wire nuts to connect new igniter since connectors are different configuration -- will that be an oprational problem.
  #32 (permalink)
Old 01-23-2009, 08:32 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by Dan Burns View Post
...cannot see how to remove the flame spreader (plate sitting under the gas tube)...
...The wires hang down behind the bottom drawer -- so I can get to them -- but will need to cut and use wire nuts to connect new igniter since connectors are different configuration -- will that be an oprational problem.
Dan,
This is not the flame spreader. The flame spreader is on top of the burner. Do not remove this panel. Instead remove the whole burner together with the igniter, replace the igniter and reinstall the burner.
You do have to cut the old igniter wires and splice the new one.
__________________
  #33 (permalink)
Old 01-24-2009, 05:30 AM
Bob219 Bob219 is offline
Junior Member
Bob219 is on a distinguished road
Question Kenmore Gas Range Model # 362.7526890
Hi, I wanted to make sure what part I would need for my oven as the it does not work but the stove tope does. I checked to make sure the Pressure Regulator was open as it mentioned in the Troubleshooter. My guess is the Igniter but without any way to test it How can I be sure. I've been looking at the diagrams and from what I can see it could be any of the following parts, Pressure Regulator, Thermostat, Valve Safety ASM, or Igniter and since the cheapest of these 4 parts is about $50 and the most expensive is $125, I do not want to throw good money away if I can get some help in the matter. I do appreciate any help I can get as this was completely sudden used it Monday and we had no problem but we went to use it on Tuesday and it would not lite.
  #34 (permalink)
Old 01-24-2009, 06:07 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Bob219,
If you would like to avoid guessing and replace only a part which is really bad then you have to invest some money and buy a simple multimeter to perform some troubleshooting. Let us know when you ready.
__________________
  #35 (permalink)
Old 01-24-2009, 06:16 PM
plink49 plink49 is offline
Junior Member
plink49 is on a distinguished road
Default
I'm also having to replace the oven igniter on the XL44. My range is a Hotpoint RGB745WEA1WW. When I remove the oven floor I can easily see the igniter attached to the burner but I can't get to the two attaching bolts. Removing the one screw at the front of the burner doesn't help much. What is the next step to remove the burner?
  #36 (permalink)
Old 01-24-2009, 08:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
plink49,
Remove the bottom drawer. The Bake burner is mounted to the rear panel with the two screws besides the front screw.
Here are the break down diagrams for the Hotpoint range Model RGB745WEA1WW
__________________
  #37 (permalink)
Old 01-26-2009, 04:16 PM
Junior Member
Default
Thanks Gene,
Other than the fact that whoever designed the location of the mounting bracket for the burner should be put in front of a tribunal, the replacement of the igniter went very smoothly. The bracket with the 2 screws with hex heads is where you can't get a socket or wrench to undo them and took me 3 times a long to remove/replace that bracket than the remainder of the job. I wound up replacing the screws with stainless steel sheet metal screws with phillips heads so they can be removed at least a little bit easier the next time.
This forum is great!
  #38 (permalink)
Old 01-26-2009, 04:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
We are glad you were able to fix it.
__________________
  #39 (permalink)
Old 08-25-2009, 06:50 PM
chicagocarrie chicagocarrie is offline
Junior Member
chicagocarrie is on a distinguished road
Default Maytag Gemini MGR6772WH
I have a Maytag Gemini Gas range MGR6772WH. In order to replace the ignitor, do I need to pull out the range and access the connections from the back? Thank you....
Carrie
  #40 (permalink)
Old 08-27-2009, 10:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Carrie,
No, you do not have to do it. It is pretty good access from the front of the range.
- The oven igniter Part number: AP4102012
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven igniter kilowat Oven Repair (including Ranges and Cooktops) 12 10-25-2007 08:20 AM
oven igniter does't heat up poplin,earnest Oven Repair (including Ranges and Cooktops) 1 09-19-2007 08:12 PM
Control Board Installation Instructions tbj66 Refrigerator & Freezer Repair 3 09-11-2007 11:53 PM
Replaced the igniter and there is still no heat in my oven??!! Ruben Oven Repair (including Ranges and Cooktops) 1 08-21-2007 11:44 AM
