Gas dryer running but no heat
My dryer runs but there is no heat. The timer cycles except on the Automatic setting. There was no glow at the gas ignitor so I replaced it. Still no glow. Any ideas ??? A sensor maybe? Any help would be much appreciated!
The first thing I would check for continuity is the thermal fuse (#7 on the bulkhead parts break down diagram).
If the thermal fuse is blown, it has to be replaced together with the cycling thermostat (#9 on the bulkhead parts break down diagram).
Here are the break down diagrams for the Whirlpool dryer Model LGR7648KQ1
It was the thermal fuse!!! Thank you for all the links you posted also. Was a major help. Repaired for less than a service call only! My dryer now runs just like it did before… :slight_smile:
[quote=RBYRD9.1;11797]My dryer runs but there is no heat. I Have a Question. My Dryer will run but has no heat. If you put it on a regular cycle it will run all day and all night. I put it on 70 minute dry and it still has no heat but will stop after 70 minutes.. Anyone have a suggestion??:frowning: Thanks
Hi RBYRD9.1,
Hi missieann33,
In order to provide the most accurate advise I need the complete model number of the dryer.
Post it as a new thread, please.
My dryer stopped heating again. I have changed the thermal fuse again and the cycling thermostat. It will cycle once and then does not heat again. The ignitor glows but it does not kick in the gas to heat.
Is this the heat coil?
[QUOTE=RBYRD9.1;75091]…The ignitor glows but it does not kick in the gas to heat.
Is this the heat coil?..[/QUOTE]
Yes, most likely the problem is a bad gas valve coils. Also make sure there is no obstructions in the vent lines and the blower housing is clean.
  • The part number for the coil kit is AP2150379
Thanks again Gene! I replaced the coils and the dryer runs and cycles fine now.
You are welcome. Hopefully the problem is solved.
[QUOTE=Gene;76103]You are welcome. Hopefully the problem is solved.
Gene.[/QUOTE]
gene, similarly, my gas dryer will start hot, then some time during its cycle go cold, the clothes will not be dry…i am guessing the cdryer is hot only for 5- 10 mins then will not get hot again for over an hour after shut off
Replace the gas valve coils.
HI GENE,
I HAVE SIMILAR PROBLEM WITH MY DRYER.
[LEFT][COLOR=#000000]My dryer runs but there is no heat. The timer cycles except on the Automatic setting! I FOLLOW YOUR POST HERE BY REPLACING THE THERMAL FUSE AND CYCLING THERMOSTAT from your company(btw fastest service ever :slight_smile: . MY AUTOMATIC SETTING WORK NOW BUT IT SEEM LIKE it working intermittently. FIRST LOAD automatic setting didn’t turn, SECOND LOAD FINE. I look through the peep hole there was a glow at my gas ignitor and fire but after a couple of minute it turn off by it self. Obviously my dryer is working much better than before and finally it heat up but not all the time :confused: please help! [/COLOR][/LEFT]
[quote=Boeing747400;287219]HI GENE,
[/quote]
Make sure the dryer vent line is clean all the way through the vent outlet.
If it would not help, replace the gas valve coils.
:smiley: problem solved with the Gas coil thank you so much Gene for your help.
Now my dryer is working like new again, total cost for repair include shipping is less than $55 awesome awesome awesome
[FONT=Calibri][SIZE=3][COLOR=#000000]I have a similar situation. The dryer starts and the heat starts, then the heat goes out. It eventually starts back up again but it is taking a very long time to dry clothes. My wife noticed that the time default time is displaying 31 minutes now, before it was 60 something if that helps.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]I have replaced:[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]Thermal Fuse[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]Thermistor[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]Gas Coils[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]Hi Limit Thermostat[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]This all started after I opened up the dryer to replace a squeaky Idler Pulley. [/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000] [/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]Any ideas of what to do next?[/COLOR][/SIZE][/FONT]
Maytag Gas Dryer
What is the complete model number of the dryer?
Have you checked the blower and the dryer exhaust line?
[FONT=Calibri][SIZE=3][COLOR=#000000]Thanks for the reply.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]I have a Maytag Gas Dryer, model # MDG5500AWW.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]I took off the flexible line and cleaned it out (it is only about 8 inches long) and cleaned out the vent (it goes up to the roof) as best I could.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]I’m not sure what you mean by checking the blower, here is what I have done. I ran the dryer without being hooked up to the vent and heat comes out.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]Update:[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]I ran a full cycle without being hooked up to the vent and had the same issue (clothes not drying).[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]I found a Sensor Bar Assembly that failed the continuity check so I am currently waiting for that part. Could that be causing the problem? One of the past posts mentioned that the High Limit Thermostat could be bad even though it passed continuity. Should I replace it ?[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]Looking for some help, thanks.[/COLOR][/SIZE][/FONT]
