[FONT=Calibri][SIZE=3][COLOR=#000000]The blower wheel is in good shape.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]I rechecked the continuity on all of the parts and noticed that the Thermistor gave me resistance of 8ohm (if I am reading it correctly). Should this part be 0 like the rest?[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]My model number is MDG5500aWW with a serial number of 56756985AX. If the Thermistor is ok I will order a new high limit thermostat.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]Thanks Gene.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]I ordered the part and will let you know how it goes.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]This all started when I replaced a squeaky Bearing Idler Assembly . Can you think of anything that might have caused this problem. Could I have re-installed something wrong when putting it back together? Can the electric motor direction be reversed? I am grasping at anything at this point and am willing to look at any possibility. If I were to star this all over from the beginning, what would you have me check/replace?[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]I see the flame come on and stay lit for about 2 minutes. It goes off for about 2 minutes and then it lights back up for about 30 seconds.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]Update:[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]I changed the High limit thermostat, it had no effect.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]My symptoms are that the dryer can run (on timed drying) for an hour and the clothes are not dry. If sensor dry is selected, the timer counts down quickly (starts at 60 and is at 20 in about 10 min)but when the buzzer sounds the clothes are not even close to being dry. Any ideas on what I should look at?[/COLOR][/SIZE][/FONT]
Here are the break down diagrams for the Whirlpool dryer Model LGR7648KQ1
Gene.[/quote]
Hi Gene,
I have order and replaced all these parts from apliancepartpros.com (Ignitor,Thermal fuse,Hi-limit Thermostat, both Gas coil valve and thermal cycing. I have checked the blower wheel in good shape and clean vent to the outside. Turn on dryer, the ignitor glow for 20 seconds and then goes out, I could smell the gas, but no flame.Can you think of anything that have caused the problem. Please help! User Mqcheng64 .Thanks
[quote=mqcheng64;343279]Hi Gene,
I have order and replaced all these parts from apliancepartpros.com (Ignitor,Thermal fuse,Hi-limit Thermostat, both Gas coil valve and thermal cycing. I have checked the blower wheel in good shape and clean vent to the outside. Turn on dryer, the ignitor glow for 20 seconds and then goes out, I could smell the gas, but no flame.Can you think of anything that have caused the problem. Please help! User Mqcheng64 .Thanks[/quote]Maytag MDG8600AWW Dryer
Hi Gene,
I have replaced all these order from Apliancepartpros.com ( ignitor, Thermal fuse, Hi-limit thermostat, Both gas coil valve and cyling thermostat). Checked all parts passed continuity, checked blower wheel in good shape and cleaned vent to outside and still have same problem. Turn turn on dryer the ignitor glow for 20 seconds and then goes out, I could smell the gas , but no flame. Can you think of anything that have caused this problem. Dryer Model#MDG8600AWW Maytag . Please Help! Thanks
Got a gas dryer Whirlpool model SGDX600JQ2, the timer is not turning, heat will kick in for about 5 minutes, then the heat will shut off, the dryer will keep on turning all day if a do not shut it off manually. I need advise an what to part to buy. Matt
Hi Gene,
This is Mqcheng64 , I received the Gas Valve today from APP. and installed it, it’s works few times and goes back same problem. what do i do next?Thanks
[QUOTE=mqcheng64;345249]Hi Gene,
This is Mqcheng64 , I received the Gas Valve today from APP. and installed it, it’s works few times and goes back same problem. what do i do next?Thanks[/QUOTE]
Unlikely, but there is a small chance that the flame sensor contacts open prematurely.
Hi Gene,
The gas valve came in today from App and I installed it. I tested a few times it’s works fine. put everything back together and test a first load and went back same problems.Please advise , Thanks mqcheng64
Hi Gene,
The gas valve came in today from App and I installed it right away. It’s works first few tested.After I put it’s together then test a first load and went back same problem.The ignitor glow for 20 seconds then goes out I could smell gas but no flame. Thanks
The possible problem with the flame sensor I mentioned in the previous post can not be proved by continuity test. I would just order it and give it a try.
