Brand: GE
Model Number: DBVH512GF0WW
Main Symptom: Works for 3-5 minutes, igniter comes on, but flame does not start after warming up, followed by a clicking noise and shutdown.
No error codes
changed the Inlet Control Thermistor
It would be recommended to put the unit into service mode and see if there are any stored error codes. Here is a copy of the service manual which will have this information in it.
The display showed E00, no error codes, i read the manual and i ended up running a temperature test, after two cycles, it only got up to 155 degrees and then it declined all the way down to 90 without any flame coming out before I stopped the test. I also when back to T02 and cleared the codes accordingly to the Instruction manual, exited service mode and tested the machine. It still does not work. Please let me know if there is anything else I can do before I dispose of the machine. thank you in advance ![]()
If the flame is not coming back on then test the thermostats and make sure that they are good. If they are then check the coils on the gas valve.
