One of the striker pins on my Frigidaire Affinity washer door broke off in the locking mechanism. I was told by the local washer repair folks all I needed to do was to lift the door off the front of the washer, unscrew the locking mechanism, and shake out the snapped off part. Can some one please help me with directions about exactly how do this?
Thanks!
I’m afraid it is not that simple as they told you. The instructions are attached to the post.
If you would not be able to shake it out then you have to replace the door lock assembly.
Here are the breakdown diagrams and Parts for Frigidaire ATF6000FS1 Washer - AppliancePartsPros.com
Removing the door safety switch.pdf (142.1 KB)
