Brand: Frigidaire
Model Number: lghb2867pfha
Main Symptom: Water drippingfrom ice maker
What happens & when: Ive been finding frozen water at the bottom of my freezer that continues to grow. Ive tracked it back to the fill tube that is clearly missing from my freezer. My best guess is that water is simply spraying out of the hole vs. being neatly dispensed into the tray.
I went to the back of the fridge to try and dislodge the water hose, thinking this would be an easy enough part to replace, but its pretty stuck in there.
Im in need of the specific part to order (I think its this), although Im not sure how this would be installed.
Need some help.
My freezer looks like this, with clearly just a hole in the ceiling of the freezer. When water dispenses, I believe its spraying all over the place.
I found another photo of the same freezer (not mine), and this one clearly has a tube sticking out to better dispense water in the tray. Mine does not have this.
