I have an Amana AKT3040E cooktop and ordered the replacement switch for the Dual Element. The part that was recommended was Repair Part Number 12002125. This is an OEM part that requires more than just a swap out of the wires and I need some help. As best as I can determine from the electrical schematics:
Diagram… Old Switch Designation …New Switch Designation
N … L2 … P2
2 … L1 … P1
3 … H1 … 4
4 …H2 … 4a
5 …P … S2
The Electrical schematic on bottom of cooktop and the connections listed on the Instruction Sheet (16023363) are attached. The switch/burner in question is the Left Front Element
Here is how I have it currently wired and the problems that I am having:
[LIST=1]
- Black Piggyback wire (incoming black wire to splice to switch and then to right front element switch) is attached at P1 (as per instruction sheet drawing).
- The Black Jumper wire is used to bridge P1 with S1
- The brown wire attached at “2” in the wiring diagram is orphaned and not connected (see below).
- The Red Piggyback wire (incoming red wire to splice to switch and then to right front element switch and then to “power on” light) is attached at P2.
- The single Red wire is currently attached to position 2
- The blue wire with white tracer is attached to position 4 on the new switch.
- The Blue wire without tracer is attached to position 4a on the new switch.
- The yellow wire is attached to position S2.[/LIST]Here are the observations:
The switch turns on the heating elements, both the smaller one and the larger one correctly.
The power light comes on as normal.
The Hot indicator Light DOES NOT COME ON.
The brown wire is left unattached.
I have tried a couple of wire combinations (not using incoming power and Load wires but nothing seems to correct the problem. I am also concerned with the orphaned brown wire. I currently have it taped off but of course that is only a temporary fix for now.
What am I doing wrong? Thank you so much for your assistance.
Kevin
kevin.odonnell@tosoh.com
wiring diagram.pdf (221.0 KB)
Instruction 16023363.pdf (171.4 KB)
