Are there two door switches on this model? Door warning comes on when trying to use the microwave even though door is closed? If two, replace both? Also what is the best door spring to replace at least one broken spring? Thanks
Remove the control panel and check the 20 amps fuse for continuity.
If any of the door springs is broken you have to replace both of them. You can find more information in one of our previous threads: http://forum.appliancepartspros.com/microwave-repair/127-replace-torsion-spring-micro-door.html
The fuse [PART]W10017410[/PART]
The left hand door spring [PART]4452395[/PART]
The right hand door spring [PART]4451009[/PART]
Here are the breakdown diagrams and Parts for Whirlpool KEMC308KSS0 Wall Oven - AppliancePartsPros.com
