[QUOTE=Gene;16242]If there is a white film on glasses and/or white staff built up inside the dishwasher - the cause of the problem is very hard water in an area.
I would recommend to use a regular white vinegar to clean the dishwasher.
Thanks for your thoughts but the problem is the rinse aid is not being released into the washer. I have another dishwasher on the other side of the kitchen and it has no problems…
I do not trust in any of a rinse aids doing more or less good job. The most important of what they don’t do is preventing of the calcium built up inside a dishwasher.
So if you do have a white film on glasses and/or a white staff inside the dishwasher - the rinse aid is not going to help you.
It is very important to chose a right detergent depend on the water hardness in your home. More information on how to do it you can find on my web site.
Also I would recommend to check if the dishwasher is getting enough water. If not - it could be cause of this problem.
