CYE22TSHHSS fridge not cooling
I have posted a lot of info in the forum below but haven’t heard a response and not sure what direction to go
Does the fridge ever get cold? Like after you first plug it back in then gradually lose cooling?
It will cool to around 57 degrees and hang around that temp
Is the refrigerator evaporator fan running?
Yes I believe it is. Is that the bigger fan i should hear running?
Yes you may have to open the doors and depress the door switches to make it come on
