How Do You Replace The Complete Burner Unit Under The Stovetop? The Gas Connects To This Piece!
Are you talking about the burner head (#2 on the diagram) or the orifice holder & tube assembly (#6)?
Here are the breakdown diagrams and Replacement parts for MAYTAG MGR5755QDQ RANGE- S/C F/S GAS | AppliancePartsPros.com
Follow the instructions posted by Joe: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/237606-burner-replacement.html and remove all burner heads.
Carefully remove the top panel. Unscrew the nut secured the gas tube for the left front burner to the corresponding gas burner valve and remove the orifice holder & tube assembly.
Assemble everything in the reversed order.
- The orifice holder & tube assembly (LF burner) AP6011424
how is the top panel held down??? thanks gene
[QUOTE=WHIZZKIDD;451608]how is the top panel held down??? thanks gene[/QUOTE]
By the burner heads.
Did you try to do anything yet? You would not see it until you will take a screwdriver and start to disassemble it.
