Bosch, noisy, leaving film on dishes
This Bosh has worked fine til now…Very noisy when on and leaves a whiteish, rainbow film on dishes…unusable now. I suspect bad pump/motor that is leaking oil into dishwasher. How hard to fix myself.
Roy
Hi Roy,
Very likely there is a hard white scale build up all over, especially in the spray arms and pumps. The dishwasher needs a good cleaning and you have to choose a right detergent in such situation. You can find more information in our previous posts: [COLOR=#0000ff]http://forum.appliancepartspros.com/dishwasher-repair/12961-how-do-i-take-remove-strainer-clean-heating-element.html#post37989[/COLOR] and [COLOR=#0000ff]http://forum.appliancepartspros.com/dishwasher-repair/7757-whirlpool.html[/COLOR]
Remove all filters and screens from the dishwasher and clean them separate. Check for a broken glass inside.
If it would not help then the circulation pump probably has to be replaced. The instructions are attached to the reply.
Here are the breakdown diagrams and Replacement parts for BOSCH SHU8805 UC/12 (FD 8105-) | AppliancePartsPros.com
How to remove the circulation pump.pdf (213.7 KB)
