In tne process of repairing and putting my machine back together I must of messed up the latch. Now the machine works but the lights don’t and the machine works with the door open or closed. Is it just a loose wire or do I have to replace the latch?
Carol,
What is the complete model number of the dishwasher? You can find it on the right side of the door.
Bosch Shu9915uc/u12 FD8009
I saw the post from another user same model. I took latch out but I couldn’t release or switch the latcht to open position or any other position.
Carol,
Hopefully attached instructions will help you to fix the problem.
Door latch in integrated models 1.pdf (410.7 KB)
Door latch in integrated models 2.pdf (388.0 KB)
Gene,
Any advice? The detergent door does not close. Something seems to be stripped. The detergent goes into the washer immediately, so I assume the detergent gets washed down the drain too early. I found three possible parts to buy.
Rinse aid door (with gasket) --$10
Part Number: AP2802335
Detergent door (with gasket) – $22
Part Number: AP2802328
Dispenser assembly (vented) – $56
Part Number: AP2802340
The dishwasher model is SHU9915UC/11
It would be great if you can help. It seems that you have good experience with Bosch dishwashers.
Thank you,
-Brian
[quote=Gene;36701]Carol,
Gene.[/quote]
My power button broke on my dishwasher. I took it a part to figure out what part to by, and when I put it back together I had trouble getting the wires on the door switch and control board correctly. Now the control lights up, but nothing happens when I close the door. DId I ruin the door switch and how can I tell?
jrmiller1
You latch has to be reset. You will need to remove and reset the spring mechanism.
This is where i am hung up. how to reset the spring..the door wont close but the dishwasher will run.
is it easy to remove the spring mechanism?
Gene–I have the same problem as Carol in that my latch won’t latch and the lights won’t work, but the dishwasher runs. I took my door apart to tighten the handle and I didn’t see that there was anything technical involved, but obviously I messed something up. My model is SHX46A05UC/23 so the documents you posted previously didn’t apply to me. Any suggestions?
Thanks a bunch! Shawna
