bulfighter10
#1 Posted : Monday, June 7, 2010 3:53:26 PM(UTC)
bulfighter10
My dryer is making a horrible grinding noise but does spin. I was able to take the top of it off but I need to look under the drum to see if something is stuck under it. I can't figure out to get the thing apart. Please help.
#2 Posted : Tuesday, June 8, 2010 2:39:40 AM(UTC)
Are you sure it is a MDE500DAYW OR is it actually a MDE5000AYW.
The following is for the 0AYW unit,
Replacement parts for MAYTAG MDE5000AYW Dryer - Ele | AppliancePartsPros.com
And a manual
http://www.servicematters.com/maytag_library/docs/16023110.pdf
Grinding is often front glides, Item 8 in Section 7.
Of course check all other moving parts.
I would also check the belt, rollers etc, might as well give it an overhaul while you have it opened up.
Give the interior including the blower wheel a good cleaning.
Also clean and check your vent system.
